Exchange Issues (A bit different than usual)
KurtNHL
Like many other people, I have the issue where I cannot connect to my exchange e-mail because of security settings. I was able to resolve the issue the first time by using Lockpicker. I had to reset my phone, root, and install fresh rom again. Now I am trying to use lockpicker again, but it doesn't work anymore. I have tried everything I can think of and have searched extensively. Touchdown can connect, but there is no way I am paying for that when I was able to get the stock email app working the first time. If any of you all can help me, that would be fantastic! Thanks.
I get the "failed to create the account please try again later message." My phone shows up on the exchange server but it says Access state: Access Denied and Access set by: Security Policy Application under phone information.
Edit: I have noticed that other people are prompt to enter a pin when setting up their exchange account. This does not occur when I set up an account. There seems to be no option to add a pin, unless I am missing something?
i set mine up as follows:
installed lockpicker
setup exchange account according to my co policy.
followed the prompts for setting it up.
then after setup i turned on lockpicker and it works to this day. if u don't it will boot loop
I was able to do it the first time I set it up, but ran into problems when I had to do it a second time. I tried every way of setting it up, but it didn't work. The IT dept. must have changed something on their end. I ended up forking over the 20 bucks for touchdown. :(
Don't enable lockpicker before setting up your account. However with Fresh, after your account is setup, you need to enable lockpicker before the screen times out, otherwise you will be stuck in a bootloop (see post above).
I can't get it to sync at all. The account doesn't get made the first time. I can assure you that I have tried every possible combination. I even put my phone back to stock before each attempt. I am 100% sure that lockpicker is not going to solve the issue. Thanks for your help guys, but I accept the fact that exchange defeated me. haha.
