Exchange lookup caller
fridberg
I know there are some apps, that will do a lookup when you get a incoming call (with a number not found in contacts) in some database, and show the caller ID.
I'm syncing towards my exchange server, and I can find use it's addressbook, but I would really like a way to get it to lookup unknown numbers, and see if they are found in our exchange ....
Does anyone know if such an app exists ?
If you are using Exchange, you should be able to sync your Outlook contacts with your phone contacts. I do this and any change I make in Outlook (including adding new contacts) is reflected in my phone contacts. When a call comes in, the phone checks it against the phone contacts (and therefore also the Outlook contacts). Works just fine.
I am using Touchdown Exchange however. I'm not sure if the sync is a function of Touchdown Exchange or if it is available with the default Corporate Sync account.
I agree and that's no problem.
The thing is that our Active Directory & Exchange have a couple of hundred users. I don't want to have all those as contacts ... because it would require me to update them manually.
In AD (and exchange) the phone number is registered, and I can choose to search for the number of any users (even if I don't have them as users in my contacts). I want the phone to lookup the same way (even if the persons is not a contact
