I am trying to use a Samsung Exhibit 2 4G to connect to home wi fi. It worked fine for about a day then stopped. Nothing wrong with router settings or home network at all - other devices and other cell phones connect with no problem. The Exhibit doesn't see ANY wi fi network, at home, Starbucks.....none. I turn on wi fi, it does one quick scan, turns off. I try to manually add network and get the message "can't save network." I've done factory reset twice - same problem. I bricked the phone accidentally but with the help of this forum I did a "back to stock." Still won't see network. Any advice is greatly appreciated
If the device was soft bricked and restored there is the possibility that an important file or service was left out or misconfigured during the process you used.
