Root existing CM7 for Marvel on Marvelc?
estabien
Is that possible at all? If I was to install it on my VM WFS, what would happen? My phone isn't activated (no 3G, testing, calling, etc,) so all I really need is WiFi.
So back to my initial question... what wouldn't work if I was to install it?
I wouldn't recommend it. There are subtle hardware changes from carrier to carrier, and you might brick your phone. For example, the Optimus S and the Optimus V are almost the same phone, but some of the buttons are mapped differently. A rom for the S would brick a V, and vice versa. Your best bet is to use one of Simon's Roms.
He does have an alpha of CM7, if that's what you're after.
Has anyone heard any updates on cm7 cdma? I tried the alpha and it just wasn't stable enough for me for daily use, I can't wait till the stable version for our phones is released.
