Help Expanding memory?
iceman322
So I want to download few more apps but apparently I don't have sufficient storage space. I read that its possible to somehow expand my memory. How can I do this?
What you need is more storge space. The way to get that is to have an ext4 partition on your SD card and use that as extra storage. This might require rooting the device. I'm not sure. There is a halfassed rom. That's stock with ext4 support. Will it require rooting? IDK. But the way to utilize the ext4 is with link2sd and that requires root privlidges.
Take a look at the rooting section of this forum. The link is at the top of the page.
Good luck.
I read and re-read everything about rooting for a couple weeks before I was like screw it and did it. But I guarantee you, I'll probably never run stock again.
Obviously things can go wrong, but ask on here if you have problems and people practically trip over themselves to help. I don't think I would have done it if not for this forum.
Now I root and set phones up like crazy for just about everyone I know lol
rooting and moding is the way to go to better your phone if not happy the way it is. the forums mare the way to learn about it all!!!!!:D:D:D
