Help Experience with BT headsets on Triumph
leonard26
I am trying to figure out if there is a best Bluetooth headset for the triumph? I have an original Jawbone that keeps dropping the connection, was thinking about changing to something else. Are there settings on the phone to get BT to work better? Also does Juice Defender interfere with it? Thanks.
Jawbone should work... you on stock rom or another rom? Also, juice defender may interfere with it. Try disabling juice defender and retrying with the headset
I've had really good results from using a Cellular Innovations CL1 that a friend gave to me. He lost the detachable headset that came with it, which is fine because I wanted to use it with an audiophile-grade Shure headset.
I use it primarily for music and video playback. When I do make calls with it, people have told me that they assumed that I was not using a headset, but was on the phone's built-in mic. It even seems to be more wind-resistant than other headsets that I've used.
My experience with battery life is consistent with the manufacturer's claims on that web page. And stereo audio quality is indistinguishable from a direct, wired connection.
I've seen it for $40 online, and I'm sure I'll be getting another one if/when the rechargeable battery finally goes in this one.
The Jawbone connects fine just after about 5 minutes it beeps 3 times, then it still shows connected but does not control the phone. I have disabled Juice Defender with no change.
