Calendar events download to the Hero automatically from G Calendar
But to upload events from Hero to G calendar you need to do this
1. Tap the day you want to set up an event on
2. Tap "add event"
3. Select your google account in "Calendar" drop menu (at top)
4. Type in the info you wish (event, time,etc.)
5. Tap "Add"
Its as simple as that, and as long as you are online, it will upload
How do I export everything from the Calendar app on the Hero?
I am having the usual horrendous problems syncing with Google Calendar
and suddenly all entries on my gCal have vanished. But they are all still on
the hero, so I want to back them up ASAP before anything else happens.
Actually there is a program that will export one or more of your calendars to an .iCal file and then you can upload to Google Calendar, Outlook or just import back into your Android phone calendar. It works flawlessly! It's called iCal Import/Export, search for it in the Android Marketplace.![]()
I just wanted to say thank you, I have been tearing my hair out looking for a way to export my Android calendar (not gmail calendar) and in one post you saved my sanity (and my hair!)
