I had Leedroid 2.3d working great with EXT3 partition. Last night I tried to use one of the HD ports which insisted on EXT4. To cut a long story short it wouldn't install. Then to my shock when I tried to Nand backup it said the nand was corrupted.
I still had the leedroid a2sd zip so I took a deep breath and installed it with the ext4 partition. After a few nervous minutes (it seemed much longer) it booted up and is working now.
But it is a little laggy and flaky which it wasn't before on EXT3. I also noticed transfer speeds are noticeably down from previous. Its a class 4 card and I was getting good write speeds now only about 1.3mb/s
I have installed everything and just wondered what is the safest / best way to get the card back to ext3. I am not worried about reinstalling everything.
Do I need to uninstall everything first or not. Or can I just gpart the card back to fat32/ext3 and reinstall everything?
Anyone help?
Anyone help?
