I'm using broken out Rom and kernel. Can I partition my sd card in order to use links 2 sd, and off so what size should I make the 2nd partition? It's a 4 gig card. Thanks.
What about swap?
Hey, I have been partioning for awhile now. I have a 16 GB & at first I made my Ext 4 (I've tried using 2 & 3 but 4 seems to work the best with this phone) I never use a swap, I don't need it. I will mention make sure you're using Link2sd simply because I have been absent awhile & don't know you. You may know this but many don't. What are you using to partition? I use Mini Tool Partition Home Wizard
