EXT2 not installing on vibrant 2.2
hi am new to this so bear with me
i have a updated vibrant (updated it with samsung kies) and i just rooted it so i bought one click lag fix but it wont let me do nothing without installing EXT2 tools. so when i tried to install it it says
you need to have 1.0 MB
available in /system/lib to
install this!
so i just click force any but after that it says
Install EXT2 tools failed with error: could not copy
library libext2_blkid.so:/system/lib/libext2_blkid.so:
write error: no space left on device
1+0 records in
0+0 records out
0 bytes transferred in 0.007 secs (0 bytes/sec)
PLZ HELP idk wat to do!!! i think i wasted my money on that app
thx in advance
get root explorer (or some other root exploring app). then go to the /system folder and just delete something from there. just be carefull what you delete! you can delete some ringtones (/system/media/audio/ringtones) you dont use or some apps you dont use either (/system/app). ive done it couple of times but since you are a rookie backup the things you want to delete. just in case ;) gl
thanks i tried to delete some apps but i would just say this app cannot be deleted i could delete the app from titantium backup but idk if it will be the same
