hroark, is there a way/program that you know of to read the filesystem data and partition info of the phone itself, not just the sd card? thanks!
please tell me journalling is enabled on this?
ok after a bit of setup and messing around I would say the ext4 support is good, though I am not so happy with link2sd. I have better free space and more apps by moving them to the /system/app what I would like to see is darktremor app2sd work, but I was unable to get it to work I flashed the beta4 listed and when I go to check if its installed I get no response.
I have never had it working on the prevail, but I have used it on my optimus M
here is a link to it. it can explain way better then I can.
[Script][A2SD] Darktremor 2.7.5.3 Beta 04 [N1] (01/29/2011) - xda-developers
Yes it does use init.d
no have not tried shabbykernel rc1 I wanted to test out the ext4 first. I doubt his would be compatible with your ext4 at this time.just out of curiosity, did you try getting it working with Shabby kernel RC1
Shabby implements init.d differently than me, and I am not sure which one is better
To be honest I am not even sure if my init.d works, no one has tested it yet
Ya, if no one tests it in a few days I will, for now I want to get an accurate account of how your set up works for me.no it would not be, I was just wondering if you had RC1 before hand and tried getting apps2sd to work, or if anyone that is using RC1 got it working
if it works with RC1 than I can always change my kenrel to do init.d the same way Shabby does it or Shabby can add the ext4 modules to his and make an RC2
I got very tired of link2sd so I redid my set up ran the shabbykernel rc1 put a2sd on and will commence testing but it isnt looking that great, In the install the only marked thing was install complete, I may have to odin back to stock and then start again.
