Extended Battery Calibration
heythereitsv
Amazon.com: eForCity Extended Li-ion Battery with Cover for HTC EVO 3D: Cell Phones & Accessories
Bought this one, reviews were good and the battery was CHEAP. Case fits fine and the battery works fine.
How long should the calibration cycle take? I've had this battery since Saturday night, and did my first charge cycle with it Sat --> Sun night. Been draining it and then charging up to green and then some with the phone off. However, when I turn the phone back on, it shows only a 90% charge. The draining behavior has changed over the past couple of days-
Monday- Drained till 50% very quickly, was pretty worried. Then it was normal drain till 40%, and it just refused to die then lol. After it finally hit 30%, I ended up playing a loop of Nyan cat at full brightness with 4G searching + bluetooth on to kill it. Lasted a good 45 minutes before it finally died.
Tuesday- Drained till 70% very quickly, drained normally until 60% and has lasted me (as of now, 8.30PM) since noon, and now is at 30%.
Normal rate is normal for the STOCK battery that came with the phone.
Used the phone about the same for both days. Also it gets "stuck" at random percentages, like it'll display 37% for 15 minutes. When I reboot, it also sometimes goes suddenly up or down.
When will this pattern even out?
I use multiple batteries and use Better Battery Monitor which allows me to calibrate multiple batteries by just telling the app which battery is in use. Might be helpful to you.
How's it working now? Would you be able to take a pic of the extended battery and back while it's on the phone pretty please?
By the way, EasySteve-
I just realized how much I hated my old phone haha. Soooo slow! xD
4000mAh Seidio
