yes. it puts to much pressure on the battery which then presses against the back of the screen. this can cause a rainbow effect on the screen and mess with the touch accuracy. also the batter needs a smidgen to breath. i would use the new cover.
http://www.youtube.com/watch?v=heRNHDObU6c
Yeah, I always use the extended cover.. UNLESS I have the phone in a case, then I go bare-back literally.... I figure that the ext batt is just about the same sixe as the phone w/the stock door on, so the case will naturally act as a door for holding the batt in.
