Make sure to have:
Bluetooth off when not using it.
Wifi off when not using your phone.
Make sure to have GPS turned off when not using it.
*Turn off background data.
That's crazy!! We have smartphones, don't we??!! I don't want to micromanage every feature everytime that I turn it on! What the hell is the ext battery for?
or just setup an auto scheduler?
which is what a smartphone is capable of, and you should take advantage of that.
Also, there are many other factors that might affect battery life, maybe a background app is running that you are unaware of.
Try contributing to the topic next time.
I get around 7 hours or so out of my extended battery with 50% screen on and nothing turned off, 4G etc.
