Received the extra batteries with charger and after about a week here are my findings. Took about 17 days to receive item. One thing I noted was that you have to train your phone going from a 1600mah to a 2000mah battery. Once you complete the training for the new battery you will be just fine. Here is how I did the training; credit goes to "Alsaces Daddy" who posted these steps.
"Do you have cwm? Go in to it and go to advanced settings. Click wipe battery stats. This is only after charging the battery to the FULL 100% with the wall charger you said will charge it completely. Not in the phone. Then let it drain all the way down to 0%. A full battery drain. Then charge back to 100%. It should recognize the new battery after charging and depleting a couple times. But you only wipe stats once."
I persoanlly haven't had such luck. Mine is more charging with the phone as apposed to thee wall charger.
To simplyfy it
wall charger (out of the phone) = 12-22 hrs...depending on usage
Charging with the phone = same as the normal factory battery.
Its not the battery, its the way the phone charges the battery.
See my post for more info, and no this is of a plug to get more views, this is just a breif version...the post is a little more detailed is all.
UPDATE:
Short version so as to not post the exact same thing in both posts.
It seems as if the battery is indeed working correctly.
An updated post is here http://androidforums.com/zte-warp/549331-zte-warp-batter-charging.html if you wanna read any more detail.
