Mexiicanboii
Member
I am going to metro pcs corporate store tomorrow to buy an extended battery for my LG esteem I was wondering do they change the battery or do you just buy it to then change them yourself, because my phone is rooted
OK thanks ill try ebay, any good links? It would help.
Can you guys recommend an extended battery that works on the stock battery cover
