GalaxyNexus
In case any of you have the Sedio Surface case, like me, and you're stuck with your extended battery. Well, I figured out a way to make it fit.
All you do is put the ext. Battery in.
Put the original back cover on.
Then snap on the two piece case! Works like a charm.
