extended battery question
does anyone know if the extended battery will manage to fit in the stock battery cover or if the new battery cover is needed?
You have to use the bigger battery cover. There's no way it will fit inside the normal one. If it did they wouldn't include the bigger cover.
Yeah no way it will fit. The battery itself comes up higher then the camera lens. Its pretty chunky hehe :)
