nickman101
I wanted to buy an extended battery for my Boost Mobile LG Marquee, and all I found was this one for the Sprint LG Marquee: http://www.ecrater.com/p/13804127/3500mah-extended-battery-for-lg-marquee?sa=X&ei=pj1pT7fhIoT0sQLMndmLCQ&ved=0CGMQgwgwAQ
My question is, will that one work for my Boost Marquee? Does the Sprint Marquee have the speaker on a different place than the Boost phone does? I only ask because I don't see a speaker hole on the lower left hand corner of that extended battery. Also, if anyone knows where to get an extended battery with an extended battery door for the boost marquee, could you please post the link? Thanks.
