OutOfPhase
Premium Member
Do you need a different back for the extended battery like you did for the X2?
Yes, it comes with one.
I am at 32 hrs and 25 minutes since touching a charger of any kind...and I still have 20% left. This is on 3G though, no 4G in my area yet.
Currently sitting at 1 day 40 min 59% left, been on 4G the whole time. Granted the phone has been idle the majority of that time.
Here is a link on motorola's support form. It basically says in order for the extended battery to read and work correctly you need to reset the stats.
https://supportforums.motorola.com/message/440858
I'm at 40% after 10 hours with 4G, wifi and power hogging Bluetooth on the entire time. Moderate use with a couple hours of music playing.
I have the extended battery in and after 17 hours of moderate use i am @ 30%
I am also on 4g 90% of the time.
How long does this battery take to charge fully, i got mine today and have had it connected for over 2 hours and i still have not seen any percentage increase it got to me with 20% charge and at the end of two hours it is still there, do I have a bad battery or is the first charge horrendously slow, i dont want to leave it on all night to find out it is not charged on my way to work in the morning.
My extended battery arrived today. Figured I'd do the drain and recharge as described herein. I installed it at around 1:00 and it was showing 20%. I've done everything I possibly could to accelerate the draining process (GPS, bluetooth and WiFi all enabled, screen set to 100% and no timeout) and it just finally died at 8:10. This should prove interesting.
Got the extended battery yesterday. It was at 20% when installed in the phone. I ran it completely down which took about 8 hours (screen on at full illumination & set to never timeout, GPS Bluetooth and WiFi all on). It took about 3 hours to completely recharge. I am at 50%, 21 hours later with moderate to heavy usage in a 3G only area.
I am impressed enough with this battery that I'm seriously considering ordering a second one while they are still 50% off.
I think Moto/Verizon should have shipped the phone with this as the standard battery.
I know I'll probably be overclocking at some point in time, and I have tons of apps that run services (about 30 so far) and I'll be a moderate to heavy user...
So I just bought a second extended battery for my phone. The external battery charger I got with the CostCo bundle accommodates the extended battery, so at half price from VZW, makes sense to buy 2 and have a backup / spare that is charged and ready to go when the first one dies.
I was doing this with my OG DROID running CM7 but with regular batteries - and I had to change them out almost every half day. With this, at least for now, maybe I can get the most from my batteries and phone before I have to swap out...
Been using juice defender from day one so no idea if its helping or not. Going on 24 hrs without charge and im at 30% with moderate use and lte half the time. Sure beats my droid 1
