Has anyone tried the extended battery? Is it much heavier or bigger? How does it compare to stock?
Yes...this is my first day using my extended battery and I LOVE IT !!! let me say that again I FREAKIN LOVE IT !!! Turned on phone at 5am using it my normal use as I do it is now 8:46 & I still have 47% left. It does make the phone heavier of course and thicker, however I put it up to my wife's Motorola Droid X w/ a regular battery and case it is about the same size. I find the phone a lot more easier to hold on to as well w/ the extended battery. While my battery life got better each day using the regular battery I just felt better going w/ the extended battery. You can get the extended battery for $29.99 and cover for like $9.99. Please note the extended battery case they picture in their picture is different than the one you will receive. The one you get is the exact match to the regular cover just bigger of course. Just remember you can't use a protective case w/ the extended battery, they don't make one that fits.
can anyone post a side picture?
I want to see the bump
If you use aftermarket batteries doesn't that void your warranty, say if the battery overheats or causes any damage to your phone?
