Just ordered my extended battery for half price through tech support.
How did you buy it. At a Verizon store or over the phone.
what case are you using with the extended battery?
It takes my battery , any battery for that matter forever to charge, stock battery from under 20% is atleast 6 hrs , the extended is taking 15 hrs to charge full from about 10 % , how long is it taking you guys to charge your batteries ?
You need a 2 amp charger for fast charging. USB or low current charger will be slow.
Also, if the phone is working hard such as Google maps navigation or streaming video while charging, charge time will increase.
I have a wall charger that plugs directly into the wall socket. There is no difference in charging time when I charge the battery when its in the phone. Anyways, I really believe it takes way to long.
Also, question for those who are rocking the extended battery... did you go with the one from Verizon (2750mAh) or the Seidio one (which is supposedly 3200mAh)? I've heard quite mixed reviews about batteries not being rated at their advertised values, but anyway. I was just curious, I'm guessing most went with the 2750?
