Root Extended battery
BRAINZ2013
Extreme Android User
hello forum viewers and beyond i have a extended battery in my esteem well since i got it , the extended battery i been charging it up in the esteem, hey i can't complain it did the trick i can go 10 hrs. well on Wednesday i did a trick since i was bored :rolleyes: i took the extended battery charged in the esteem for over night which put me to Thursday. i woke up seen the phone said fully charged, yes the green light was on and the battery was fully green. i poped the battery in the extended charger that came with the battery. this charger said it was only at 70% funny so i plugged the charger in and it chared the extended battery for a total of 3.5 hours before i see the blue light ,this is the indication that the extended battery is fully charged. so this charging in the esteem will take 9hours of charge plus 3 extra hours= 12 hours of charging. did i do something wrong or do i need to send what i think is a defective extended battery back. someone can explain or help me out with this one :stickyman::bike::motz::car:
Like those animations huh? lol
Sounds like your phone isn't reading your actual battery stats right.
If you are rooted, boot into recovery and try clearing the battery stats.
Also when you got the battery did you fully charge it, fully drain it and fully charge it again before using it as normal?
well i can say i did the stats wipe in and out cwm i even have the tool box, charge kill and wipe. the directions tell u to do a 8 hour charge before use the extended battery.
