Root Extended mms.apk
M
Member 893895
Guest
Here's the mms.apk from cyanogenmod 7.2.I'm not sure if it works on all rom's. I know for a fact it works on roms that run stock 2.3.4 so i'm not sure if it'll work for 2.3.6. I wanted this mainly because of the fact you can switch between black and white backgrounds sooooo yeah.
Cyanogen_Mms.apk
Also this isn't my work. Just something I found on another forum
Edit: forgot to add instructions for the noobs lol.
  • Download the file and put it on your sdcard and rename it to Mms.apk
  • Go into /system/app with root explorer and rename your original mms.apk mms.apk.bak
  • Move or copy the mms.apk you just downloaded to /system/app
  • Change it's permissions so that every box under read is checked and the owner box under write is checked and every other box should be unchecked
  • Reboot and you're good to go
Look at the attachments to see how it should look
P.S. Mms doesn't work with this still sooo yeah lol
I would also like to get something like this, at least a black messaging theme
Well i was able to get the default mms.apk from cyanogenmod that lets you change the background from black or white if you want it
Yeah it's a modified version that i found on another forum. I'm using it on monster so it should work for any rom
Lol alright. This is one of those times where scouring google for minutes helped.
First what version is it? Is it for 2.3.6 or 2.3.4 os? Go to settings and go to mms and see what version its for please lol don't wanna mess my mms up
how do you install it? can i get some instructions please. do i delete the old mms.apk?
Sorry about that. I updated the OP and added instructions.
It's neither lol. It's messaging 2.3.5
