Help external camera
hamahmoud
Hi!
I have a telescope with digital eye-piece "iOpton iE 1300" with USB cable. Is it possible to be connected to Gnote 2? I tried it but didn't work.
Please advise.
HA
You could try using an OTG (on the go) cable to connect them. Even if it doesn't work, they're usually under $2.
Thanks 4 ur reply, I already have OTG cable, but even after connecting the digital eyepiece to my Note2 it didn't work. My note2 couldn't see the eyepiece
