External Sd Card
Its should show when it shows the internal. Go to your settings>storage and mkae sure your card is mounted. If anything if theres nothing on the card format it.
LG Esteem comes with an Internal SD card with 2 partitions (internal and external) your computer only sees the “external partition” of the internal SD. You can buy, install and mount (as shinySide said) another external SD card and then your computer will see two SD cards (one from the phone and the other you bought)
is there a way we can change the permission to the external memory card to root. its at system which causes our issues
so that we can use or external instead of internal. the permissions need to be changed. and if you try.
i was comparing my optimus. and the permission on that sd is root. also on esteem. the internal permission is root. so i was thinking if we could get the external to also be root. oh the places we could go
