Help External SDcard
I was wondering that myself. I always use the flip-flop script so it's always been a non-issue for me.
It flip-flops the way that Android sees the int and ext sdcards. So everything goes to the ext sdcard. The only time they won't be switched anywhere is in Bootstrap Recovery (because Android hasn't been booted up yet).
edit: There are some script links in all things root guide sticky.
Just keep in mind they will be labeled the opposite of what they really are in all your apps. For instance, if you open Root Explorer and choose sdcard-ext, you'll really go into the internal sdcard.
