Yes. I'm running stock 2.1 and have also installed the OTA update from HTC.Anyone have it this bad?
1% at the moment. I know about changing the radio band to CDMA Auto PRL, and do it after every reboot, otherwise my TWS climbs back into the double digits.Kelmar said:What's your time without service.
Yes, and it says the top offenders are:Kelmar said:Also, have you tried using spare parts to see what's keeping your phone awake?
im looking a for another battery widget which one is better in the market?
Any widget will drain the battery
