Exynos 4 Security Hole for some Galaxy SII
I took a quick look at the T-Mobile Galaxy S2 and I am pretty sure the hercules does not use the Exynos 4. It is this piece of information that does not have me worried about my phone!!!
It makes for a very easy root method for phones that are affected.
Samsung will patch it in no time
I think the only thing is that when you plug up the hole with one of the app fixes you lose the camera functionality but you do gain easy root. Not that it was hard before with Odin :-)
http://forum.xda-developers.com/showthread.php?t=1993044 The GS3's issue is with the motherboard flopping. The Note 2 has issues with the Exynos exploit. This upgrade for me, looks like it is going to be awhile. I'm starting to think Nexus at this point.
