F1 GalaxyNexus| Pure Galaxy Nexus Experience
l14m3
Member
Has anybody tried this ROM yet? It looks pretty good based on AOSP.
F1 GalaxyNexus is a ROM built entirely from Google's ICS source code. The main idea behind this was to give users the experience of pure ICS as it is on the Galaxy Nexus with no visual changes and ZERO bloatware or any 3rd party app. F1 GalaxyNexus is just plain AOSP ICS with under the hood tweaks, optimizations and the features to make AOSP a little bit better. Big Kudos to Teamhacksung as without them this ROM was not possible. This ROM will be updated on a daily basis and will be also updated whenever Teamhacksung improves the device tree or patch new stuff.
System Details:
Android ICS 4.0.4 (IMM76I - Android-4.0.4_r1.2)
Latest CM Source Compiled Kernel
Multi-Language
All ICS Features and Apps (Nothing excluded from AOSP)
No Visual Changes!
Stock ICS Look and Feel
This will turn your Samsung Galaxy S2 into a Galaxy Nexus
ROM Features:
Fully Deodexed
Zipaligned APKs
Rooted (Superuser)
BusyBox Installed
No 3rd Party App
ZERO Bloatware
Official ICS Bootanimation (From Official Nexus S 4.0.4 Firmware)
Extended Power Menu (Reboot, Recovery & Download)
Galaxy S II Settings In The Launcher (Device Settings)
Tweaked Scrolling Cache (Smooth Scrolling)
Huge APN & SPN List (Thanks To CM)
Patched Settings with F1 Version
EXT4 File System Optimizations
SD-Card read ahead Tweak
Init.d Support
Fully Working Mass Storage
T9 Dialer Functionality
Landscape Dialer Support
Notification Toggles (Press and hold the settings icon in the notification bar to reveal them)
180 degree rotation enabled
Both MTP/UMS Support (Settings>Storage>Press Menu>USB Computer Connection)
Video Recording in MP4 with higher bitrate and Stereo Audio Recording
Storage Option In Camera (Internal SD Card, External SD Card & USB Storage)
F1ROM Build Prop Tweaks
Enabled GPU UI rendering
Been using it since build 3, it's exactly as described and rock stable!! The only little issue at the moment is auto brightness isn't quite right but will be corrected in build 5. Other than that no problems!
Just thought I would mention the I have spent a week or so playing around with different roms such as slim ics, paranoid and obviously F1 which has been my main rom. However I also installed Clean Blank Rom by luca89 on xda and its amazing! 100% pure galaxy nexus experience even down to the apps, and it runs as smooth as silk!!!!
So as an alternative its worth giving it a try, F1 is great, but modified slightly. CBR is like your actually picking up a nexus instead of an s2, barring the soft keys but they only take away from the screen so who needs them!
