Root FA19 Limbo
BigAlHurl
OK....
I rooted my phone 6 months ago and things were just fine until this update. I really only wanted to remove some bloatware and use a wireless tether. I allowed the update and it seems to have partially unrooted my phone. I have my phone usage plus some bloatware back (scavenger). I however cannot retrace my steps on the root and get it to take. I have tried to phone factory reset and it comes back with this FA19 update.
Does anyone have a way to reset this phone to preFA19 Update using ODIN? I would be fine with going back to original Factory OS and working my way back if needed.
I appreciate any help and any direction the more knowledgeable can spare for the lesser gifted.
Thanks
BigAL Hurl
read this post download rooted ej06 image flash with odin...if you want just stock ej06 without root use Koumas stock image
http://androidforums.com/showthread.php?p=2953252
If you install the rooted version of EJ06 , you will still get the update unless you do one of the following :
Install CTMod 3.2
Install CM7
Install an app like Autostarts to disable the update .
Install the rooted version of FA19 .
I haven't heard of anyone getting the update if they have done one of the above mentioned .
Wanted to say thanks to all those who quick funneled me to my answers. I decided to flash a rooted image of FA19 using ODIN. It was quick and simple. I was able to sign on Google Play and reinstall my apps within 20 minutes and set up my email and contacts within 10. I was back up and fully running within a total of 40 minutes after the downloads.
Thanks Again!!!! You guys ROCK!!!
