I'm kinda confused by your question. Are you looking for a backup method for your contacts or something else? For contact backup, just use gmail, don't bother with backup assistant.
If you're trying to sync your FB contacts to your phone contacts so you can see their picture, I found better luck using the FB for Android app, the FB for LG app seems to be garbage when it comes to syncing.
