Help Facebook pictures not syncing
R Deep Singh
As you know, when you sync and link your contacts on Facebook to the ones on your phone you can get their profile picture and status as the contact picture for whenever they ring. My statuses are working ok but the pictures are not updating. Any ideas?
I have a solution to this, but I'll warn you, its not quick, easy or fun.
DELETE FACEBOOK FOR HTC SENSE from accounts and sync
And then link normal facebook contacts to all your contacts and the pictures will appear (without the little F in the corner) and they will update daily
You can force a sync (there is an app available that does this, but cant remember the name), but its something you'll have to do manually every few days.
The problem is with Facebook for HTC Sense, so removing it completely will save you all the hassle.
I decided to get rid of it when facebook had a brief outage, Facebook for HTC Sense failed to sync, it decided to unlink ALL my contacts, and then when it did sync an hour later, only half the contacts came back, and even those few didn't link automatically
hey mate, if you want a quick (and easy) fix for this, download SyncMyPix from the market and it should do the job :)
