Old Member
Android Expert
I came across this at XDA, works great if you install the .zip file first. Worth a look.
xda-developers - View Single Post - [Solved]Samsung Fascinate Live Wallpapers
1. Boot into CWM and update with the fasclwp_ap.zip
2. Reboot
3. You will have to install the APK files themselves.
TATLiveWallpapersSpark.apk
TATLiveWallpapersLuminescence.apk
TATLiveWallpapersLayersOfLight.apk
TATLiveWallpapersForest.apk
TATLiveWallpapersFlow.apk
TATLiveWallpapersConnection.apk
Then they should all show up in the Live Wallpaper menu and work
2. Reboot
