arenaman
After a year I've now got 2 problems with my usually faultless Desire.
It's developed a problem with the camera and camcorder not working, just getting black screens, after contacting Orange it will have to go back to HTC for them to sort apparently
Whilst trying to sort the above I did a factory reset and since then the battery life is terrible. Whilst not running or synching anything other than having data enabled(which I always have) it literally went from 100% to less than 10% in 5hrs whilst not touching it. It was running hot as well as though it was working something but the app manager and checking data usage say it wasn't.
Would the reset have any impact on battery life? I know they need "conditioning" from new but this just seems strange.
Any help? Thanks
Edit
Ok this morning I took it off charge to see the reboot screen, rebooted and it immediately said 97% and the battery was cold. It only dropped a couple of % in an hour which is good.
I then though that I'll try the camera again, no good black screen so exited out to home screen. The battery then warmed up and started draining. It's as though it's trying to run the camera app but can't and has got stuck if that makes sense. 5 hours after taking it off charge and it's down to 35% and it's been in standby for all that time
I've just downloaded advanced task killer to see if that makes any difference.
I think I've got a rogue app running, most probably the camera/camcorder
Any help? Thanks
Edit
