So yeah im getting pretty fed up with the screen not turning on and it freezing and rebooting when im using my phone for important things.
Guess i will wait for the Connect.
You should have known that it at some point in time the phone would start acting up since you were OC'ing it to 2.2That sucks manYou should have known that it at some point in time the phone would start acting up since you were OC'ing it to 2.2
what do you have the min cpu setting set at?I dont OC to 2.2...never really went past 1.5, no reason to. Not sure why its giving me problems. i went back to the backup i made of the 2.0 kernel. Might go back to stock and sell it haha.
Thats what I would do. I would sell it ASAP, especially before the connect comes out. The Esteems value is going back down.
is this stock or with one of the custom ROMs, or dont matter?
it wont go down that much in price. this phone is only a couple of months out.
you tried restoring or going back to stock n see how it is?
Metro still has it @ 300.00 & Wirefly @ 268.00 it's more before they had the Rebate.Its already down $100
may been a bad flash.Thats what im going to do. Go back to complete stock. Maybe even unroot. Whats your thoughts PG? I dont want to say its the kernel or ROM doing this...
may been a bad flash.![]()
Its saying E: Cant mount SD in recovery. Guess im stuck with it
Did you try taking the SD card out and putting back in?
your sd card might be cracked to shorted out. I've had both happen to me. The crack was so small that I didn't notice it for about a month lol. It was more-less microscopic.
I would test it on another device if you have a sd card reader on your computer or maybe a digital camera
mine worked intermittently until it finally crapped out. Another thing you could try is formating the sd card. Just cut and paste it to your computer just incase.Wouldnt it be unable to mount outside of recovery then also?
