selecting "factory data reset" in a stock roms menu options will likely just take you to your custom recovery without doing anything. with a permanently installed custom recovery,your best bet is go to recovery,and chose the option to "wipe data/factory reset"
while this wont hurt,and may clear some caches and free space,i doubt its going to do much for your battery life.
