Help Factory Reset Deletes Folders?
It will wipe the internal storage. I don't think it wipes the sd card but you can take that out if you have one.
If you're rooted and have a custom recovery, you can use that to wipe the data partition. It's the equivalent of a factory reset but it leaves the internal storage alone
Are you rooted if so don't do the factory reset from the settings menu . only perform from the recovery such as twrp or clockworkmod
I just did my factory reset and it didn't erase my files on the SD card and all my scrapbooks were backed up through drop box and Samsung's cloud
