nucleardan
I am having issues after attempting a factory reset.
I downloaded ROM manager and used it to flash a new RUU to the system (hence removing my old Orange rubbish), I used the following ROM:
"Official_Stock_Sense-Gingerbread_v1.2__GB-2.3.3_A2SD+"
This process was successful, I also decided to do a hard reset via settings.
Once the phone restarted it went through the set up process and froze after the location settings, displaying the following message.
"Activity Setup (in application Setup) is not responding"
This then sends you round an infinite loop of restart and failure of the set up process.
I have tried to do a reset via the buttons but that doesn't work because either CWM doesn't let it or my volume buttons are a bit old and flaky.
How do I get around this start up problem because as far as I can see the phone is functional it is connecting to mobile networks and wireless I just can't get to the operating system because it is failing on the set up process.
