hello!
i've had this phone since it was released and have never gotten handcent to work properly with MMS. I would get the following errors: unknown error, generic network error, unable to send.
Stock messenger works fine with MMS, but doesn't work properly if I have handcent installed. Once I uninstall it, it's fine.
As a last resort, I "factory restored" my phone. Handcent still doesn't work. Stock messenger occasionally needs to be force closed with "the process com.android.mms has stopped unexpectedly".
I know this has been discussed, but has anyone found a fix? I've searched like mad and can't seem to find one.
One additional question.....
when i factory restored my phone, if it's supposed to be wiped clean, then why are my photos still there? i removed the sd card, but it's still showing the photos stored on the phone. is there a way to do a TRUE restore? makes me think that there are bits & pieces of apps that may be causing these problems...?!
I tried 2 different methods:
settings > privacy > factory data reset
and
battery pull > volume down > power > clear storage
thanks in advance for the help!
and
It's a mystery for sure since it works on other Incredibles. Maybe the next version will work. It has to be something on your phone, but after a factory reset the only thing left is a setting or configuration that is not reset.
