Help Factory reset
Dianajp
I did factory reset an its been hours now an the green robot still says erasing. My screen still does not power on. What can be done?
Hello there @Dianajp :)
You have the RCA Voyager tablet? (looking at your info in your user profile)
If so, try this: (emphasis mine)
Tablet is frozen or a serious error appears • If the tablet is frozen or suspended, you may need to close the app program or reset the tablet. • If the tablet is frozen or slow to respond, press and hold the power button for 8 seconds to reset the tablet. • If that doesn't work, insert a paper clip into the RESET hole on the back of the tablet, then press and hold the Power button for 4~5 seconds to turn on the unit.
Source
