If you REALLY want 2.1, see my post here on going back to 2.1:
http://androidforums.com/nexus-one/133130-2-1-2-2-manual-install-weird-build.html
Enjoy.![]()
No, I'm just hoping the factory reset would help my battery life. I was hoping it wouldn't reset back to 2.1, giving me a fresh install of 2.2.
You know, one other option is to load into recovery and clear cache.
See if that helps.
I've just reinstalled everything and signed in apps that need signing in. What would I lose from clearing the cache?
And if I've already done the factory reset, did the cache go with it?
If I do a factory reset on my FRF91 N1, will I drop back to Eclair, or will I be on Froyo with everything set to default?
Battery drain is killing me, I want to get this done before trying other directions.
And how long is your battery lasting?
I have seen some reports that the JIT enabled in 2.2 increases battery drain but when I was running stock, I didn't really notice any difference between Eclair and Froyo. Drain was worse with Cyanogen's rom IMHO.
So what I am saying is try to identify settings and apps that could be the source of the drain - e.g. Browser settings for plug ins (Flash!) set to On Demand.
I am running Enomthers rom specifically as the battery life is much improved over stock and other custom roms I have tried.....may be an option for you, if interested in rooting in the future.
After the factory reset I saw a post about fixing the car dock volume, so I went ahead and rooted. Using CM6RC2 atm.
My battery life was as bad as 10% an hour. Right now I think our might be the constant switching between H and 3G. Couldn't tell it was doing this until I flashed CM.
