I need to completly wipe the moto cliq! only problem is that im locked out... is there any way you can do that??? like like on the mytouch or the G1????? please help!!
If you are locked by screen lock ... if you try enough times in a short period ... the phone should have you log into your gmail account and then you can reset the lockscreen settings ...
Press and hold the camera and power buttons together while inserting the battery until the boot loader menu appears. press the volume down button within 10 seconds. Press ALT+L to bring up options
