Factory Reset?
Env2
im thinking about buying a eris off my friend and its rooted and lags alot. and i want to start from scratch is their a way i could like reset it to unroot it and delete everything on it so its like "out of the box"
[ROM][9/25/2010]FlashBack15 v1 -Return to Factory Stock - xda-developers
It's pretty easy now, but have your friend help you out with this if he has more experience rooting and applying ROMs on the Eris than you do.
In fact, I would make it a condition of the sale: "I'll buy it off of you only if you successfully complete this procedure right in front of me."
The activation (and also de-activation) of the phone works a whole lot better if you are using a stock phone. (If you took it in to a VZW store to activate it, and it has a custom ROM on it, probably they won't help you).
eu1
