WebOS: Settings... Device info... Reset options... more info here: HP TouchPad hard reset - PDA Smartphone PNA hard reset soft reset (Erase Apps & Data should suffice)
From the CM7 side: go to settings... privacy... factory reset. Don't erase the sdcard until you've reset both OS's (assuming you want that cleared too).
Did these work ok for you?
