Root failed root, need help
Done. And I must say that was a damn good walk through. When I first read it I was so lost, but that was step by step perfect. Anyways, thats done. What next?
take the oxygen rom put it on phone sd card
shut off phone.
hold vol down and power
vol down til u get over recovery
press power once
itll say HTC
wait...
itll start to load the recovery program...
press backup\restore
press backup
press check
itll start to calculate
and now backup
(Btw im doing this at the same exact time im writing it, just for better details)
press check mark again
press back arrow
now do wipe|format on main screen
do wipe data/factory reset
checkmark
check again
wipe cache
check mark
wipe dalvik cache
check mark
format system
check mark
press back button
install from sdcard
choose zip from sdcard
press update-oxygen-2.3.2-BravoC-signed.zip
check mark
wait...
check again
back button
back button
reboot now
checkmark
*if reboot doesn't happen* take out battery and put back in then press power*
DONE!
If you ever want another rom like ICS. Just ask and ill upload it for you to download. Lmk and ill have it uploaded by tomorrow. Btw this process is like that foe EVERY rom you install. you don't HAVE to backup when you want to install a new rom. but its really recommended. as long as you have a backup of your original USCC rom, Youll be fine.
and you never have to format system again. That was just to clear the old data left over from your partitions
Same thing happens when I go to hboot. It wont let me scroll down. Then it goes to the SD Checking.... and all that I told you before about no image blah blah then says Model ID Incorrect Update Fail! and wont let me do anything....
Hey Im really sorry, I appreciate you taking your time helping me do this but I have to run to pick up my son quick. Ive delayed as long as possible. Any way we can finish this later? Real sorry. Dont wanna bail halfway through but im dead if I dont go now lol.
just look at your sd card contents on the computer.. did you ever put a pb99.img (or something like that) file on your sdcard before from your past rooting tries?
It worked and wow this is awesome. Now I can start downloading some apps. Something I really couldn't do before the root. I'm way excited. Thanks so much!
Thank you SuRoot for all of your help in this thread. I would have not been able to successfully help jreuter21 without your help.
And jreutter21, I hope all goes well for you in your future of android modding!
If you ever need any questions, feel free to PM me if its more personal. Or if its for everyone to see, just start a new thread!
See you around!:)
Do not use ROM manager, you have been warned - that sticky is there for good reason. You don't need it, flash from recovery its not difficult.
edit: never mind, tapatalk threw a fit thought last post was further up (still stands though)
Im not trying to go agenst you or anything. I now know Clockwork Rec. is really bad. But what exactly does it do to your phone that its so bad?
It's not clockwork that's bad. It's Rom manager. It adds sb additional software layer to go wrong, and does. Problems with broken back ups, boot loops, missing and broken data, corrupt partitions...
So will this perm brick the phone? Like no going back? (for the people watching at home) Or could someone use an RUU to fix this?
