JayinToronto
At some point I have been getting and now always when I power on under Data Encryption "Failed to mount SD card. Reinsert or format SD card"
I have tried the former (including re-inserting battery) and loathe to try the latter.
Initial research on the Web indicated others were having that problem intermittently and could be ignored. What I have found is that the stock apps usually cannot access the external card and that Task Mgr Storage shows SD at 0. However other apps (like B-Folders) store and access the external card just fine. My main concern is that I have some valuable voice recordings of my mother on the SD card that I can't seem to access.
Storage analysis using various file mgr apps indicate I have a total of 11.25G on SD Card with 10.04 available
I have Samsung SGGH-I727R (Rogers Canada), not rooted.
Solutions would be greatly appreciated.
