I recently downloaded Fancy Widget Pro on my Fascinate and I'm pretty impressed with all the different clock skins that are available. The problem i'm running into is when I apply the widget to my homescreen, the skins do not look the same as the samples that are shown before you download them.
Example: Many of the skins have the clock digits outlined in squares to set them off. These background squares are not showing up, only the clock digits.
Also, the weather icon is on the top of the widget instead of the bottom. Is there any way to change this? I've went through all the settings options many times. Maybe I'm just missing something. Thanks in advance.
havent seen you much around here or irc lately...hope all is well
