I have the HTC Evo Design with ICS. I downloaded Fancy Widgets because it seems that Beautiful Widgets was forceclosing way too much when I had my ZTE Warp. I thought I would try this one. How do you get the darn skins to work? I press and hold on the home screen and select the widget I want but then when I change the clock skin or weather skin, it doesn't change. Also, If I have the default HTC clock widget, I am unable to change the weather skin to a Fancy Widget one. I guess I need to know how Fancy Widgets works. I couldn't get much help from their web site. Oh, and I have the unlocked version of the app. Thanks. Or, does somebody know a good clock/weather app that works good with ICS?
