FAQ: Transformer Infinity
The FAQ
Q: Does the old Transformer Prime dock (TF201) work with the Infinity?
A: Yes. But note that the TF300's dock is NOT compatible. Also, even though the TF201 dock works, the new TF700 dock does have a different (smaller) battery, and it docks perfectly with the tablet. Some users report that the TF201 dock and tablet don't marry perfectly. Close, but not perfect.
Q: Can you connect an external USB hard drive to the tablet?
A: Yes, the Infinity is capable of USB Host mode, but you must first install the USB Host Controller app, available in the Play store:
https://play.google.com/store/apps/details?id=hu.sztupy.android.usbhostcontroller&hl=en
Q: The UI is very choppy and laggy! How can I fix this?
A: By default, the tablet is set to render UI animations at a lower priority, which conserves battery. If you prefer smoothness, you can go to Settings > Customize > High Performance.
Q: How does one take a screenshot?
A: Go into Settings > ASUS customized setting > Screenshot
Check the "capture screenshots by holding the Recent Apps Key" Box.
Q: Where can I get extra USB charge cables?
A: Cables that work with previous Transformer tablets will work with the Infinity. As of this writing, there are no TF700T-specific cables, so look for a cable made for an older Transformer like this one:
http://www.amazon.com/charger-cable-Asus-EeePad-TF101/dp/B007GJR7GS
Q: How do I adjust the touchpad mouse sensitivity?
A:Settings > Language & input
Scroll all the way down. Last section is called Mouse/Trackpad and there's a setting for Pointer speed.
Q: Is there a root exploit for the Infinity?
A: Yes. Check out this thread in the root subforums:
http://androidforums.com/transforme.../586970-root-method-prime-works-infinity.html
